G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
My system consists of: AMD Athlon 1.2GHz, 2-40 GB IDE Hard drives, 256 MB DDR
Ram, Abit Siluro T400 Graphics card, Creative Soundblaster Live MP3 + 5.1
Sound card. I am running Windows 98 SE and am trying to change to XP Pro.
I'm going with a full install, rather than an upgrade because of problems I
created when I mistakenly tried to clean the registry and messed it up.
After reloading and running 98, I thought I would try to make sure everything
was compatible before changing the OS; to make the switch to, and run, XP
Pro, as problem free as possible.
I have tried to run the compatability program from the Microsoft Website
(1st), and the XP Pro CD, both numerous times. Each time, the computer
locks up when the program gets to the "DVD Movie Player". I just don't know
what to do about it. Why is this happening? Should I just go ahead and
install XP over the 98, or is it really necessary to use the compatibility
check?
Your help and understanding is greatly appreciated![Smile :) :)](/data/assets/smilies/smile.gif)
check?
