Question Low nvme m.2 speed (Seagate Firecuda 520)
Sep 13, 2020
26
Hello.
My seagate firecuda 520 (500gb) has advertised speeds of 5000mb seq read and 2500mb seq write, I was achieving this until recently and now I get 2500mb read and 500mb write.
Updated to windows 2004 and then got 2500mb on both but back down to 500mb write again.
I have 300gb free on the drive.
Only had it for a month or two.
Crystaldisk info reports: 99% health, good, 42 degrees.
Crystal diskinfo was used to test speeds.
Thanks. Any ideas?
Can you examine CrystalDiskInfo report, and verify/confirm if it says PCI-e 3.0 (or 4.0)/x4 lanes?
And, if possible, use CrystalDiskMark default test, and post results of sequential reads/writes....
(when doing very large writes, once write cache saturated, write speeds will indeed drop down to standard SATA-like speeds like you are seeing, but, normally the CrystalDiskMark default tests will show good speeds for read/writes....)
Im pretty sure it is 4.0 lanes.
I have a x570 plus motherboard.
I dont understand how it can go from 5000 read 2500 write to a test with 500 read and write before I turned off my pc for the day?
Is there anything I can do to remedy this lmao?
