G
Guest
Guest
I just purchased a new computer. It came with a Gigabyte Ga-7ZX Athlon motherboard. This motherboard has integrated Creative 128 PCI sound.
I've already used it with my Cambridge speakers/subwoofer, and it performs fine, nice sound, good and loud. However, once I changed to my headphones, the sound became really, REALLY quiet, as well as gaining an annoying crackling sound.
I think I've gone through most of the standard procedure troubleshooting this:
- I made sure that the volume control on my headphones was at max. It was, and the sound was still crappy.
- I made sure that the Windows Volume Control sound was at max (Wave, Master, Out, etc...basically all of 'em). They're all at max, and the output is still crummy.
- I checked the board's bundled software mixer, to see if its volume controls were low. Nothing there, as they were also set to max.
- I checked my headphone connection by pulling out and re-inserting the plug, making sure it was firmly planted into the jack.
- I tested the headphones to see if they were bad, by hooking them up to my other computer, also with integrated sound, but on a PII motherboard. Checks out OK, nice bass, good volume.
- I reinstalled the sound card drivers. Still nothing.
- I checked the sound card for improper installation (me...install something...badly...NEVER). All is fine with that, but the sound is still hard to hear, and the graininess is still there.
I think I'm pretty much out of options. Nothing I do seems to work, so I'm considering buying a new sound card. Here's the kick (*in the balls*), if I do that, I won't have enough money to get that GeForce 2 GTS I had my eye on, grrr...
You can see my dilemma (I hope). Any response is welcome. I'm looking mainly for help troubleshooting this problem, as I'm practically broke as it is!
Thanks for your time all,
UnReBorn
P.S. Apologies for any spelling errors, I'm working on the world's crappiest keyboard (a SIAM United. Yeah, ? is right.)
UnReBorn
