[SOLVED] Mice comparison help please
vrm
5
PERFORMANCE AND BUILD QUALITY IS MY PRIMARY CONCERN.
Corsair M55 pro rgb VS Steelseries rival 100
both cost almost the same for me
This comparison is odd but i am vexed
Logitech G603 Wireless VS Steelseries rival 310
these too cost the same for me
between these..i am vexed whether for the wireless feature i will loose build quality or sensor features or something like that.
My suggestions:
First - look for and read product reviews for the mice you are considering to purchase. Two sources: professional and independent reviews from product neutral sites such as Tom's.
Second - look for and read product reviews by verified product purchasers.
Third - go to the product manufacturer's websites to read product User Guides/Manuals.
Fourth - go to the product manufacturer's websites to read their Forums and
FAQs. Look for what is said and what is not said....
Just do the best you can, select a mouse that meets your requirements and seems to be reliable with respect to function and durability.
Then remember that statistically any given product can fail at any given time.. AKA - bad luck, bad karma, or...
My suggestions:
Then remember that statistically any given product can fail at any given time.. AKA - bad luck, bad karma, or "Mr. Murphy".
Happens.....
My suggestions:
Happens.....
Thanks
