Hey guys,
I am about to build a new computer with the following components in order to overclock as far as I can.
e6420
asus p5b deluxe wifi
geil pc6400 4 4 4 14
sparkle 8800gts 640
big typhoon vx
etc.
I am interested in building a case as seen in http://www.pugetsystems.com/submerged.php
I understand that this system after 12hrs experiences what I would consider bad heat problems even though they found it still ran stable.
From what I can tell there are three things they did wrong.
1. Put the powersupply in the oil and below the cpu.
2. Used too small an aquarium (larger allowing more then 12 hrs to reach high temps)
3. Didnt have anything circulating the oil.
I was thinking of going for a bigger tank and leaving the power supply out. I also was going to get a fuel pump and have it circulate the oil across the cpu specifically and throughout the whole aquarium.
I was just wondering if there is any chance that this setup would allow for the same level of overclock that I would get if I just used the big typhoon vx/tuniq 120 or water.
I understand the other negatives and they arent a problem so no need to bring them up.
i.e, case cant be moved - never move mine.
cant change/upgrade components - very rare for me
possible damage to capacitors - I believe my build is all solid state. I may be wrong though so feel free to call me on that
Thanks
e6420
sparkle 8800gts 640
big typhoon vx
etc.
Thanks
