Mobo Overheating Issues - Micro ATX Build - Advice Needed!
hobo_fragginz
53
While "HWMonitor" software; shows my motherboard temp is constantly around 109-112 degrees (Celsius) even while computer is idling. During intense gameplay, temps don't increase (according to HWMonitor) but case gets considerably warm to the touch.
Is it possible I am getting faulty readings from HWMonitor and if so, is there a better application I can use to check on temps? Also, has anyone any experience/advice to help improve cooling in this case - my cabling job is quite tidy btw.
Node202 has poor exhaust and currently I have one Noctua intake fan directly onto GPU.
CPU temps look good though (between 39-46) as shown by HWMonitor & CPU-Z
Thanks in advance for advice -
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor (£305.94 @ Aria PC)
CPU Cooler: Noctua NH-L9i 33.8 CFM CPU Cooler (£34.78 @ Ebuyer)
Motherboard: Asus Z170I PRO GAMING Mini ITX LGA1151 Motherboard (£144.99 @ Ebuyer)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory (£87.50 @ Aria PC)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive (£142.88 @ Amazon UK)
Storage: Samsung 960 Evo 500GB M.2-2280 Solid State Drive (£215.97 @ BT Shop)
Video Card: EVGA GeForce GTX 1070 8GB Founders Edition Video Card (£413.99 @ Ebuyer)
Case: Fractal Design Node 202 HTPC Case (£64.49 @ Amazon UK)
Power Supply: Corsair SF 450W 80+ Gold Certified Fully-Modular SFX Power Supply
Monitor: Asus PB278Q 27.0" 2560x1440 60Hz Monitor
Total: £1410.54
Generated by PCPartPicker 2017-01-02 20:40 GMT+0000
Lutfij
You may want to see what the temps in your BIOS are reporting. On that note, have you seen if the temps of your motherboard is as the numbers specify on HWMonitor? 100 Deg C is boiling water temps and the system shouldn't be operating at that temperature for even a minute, the system would've shut down immediately.
It's actually an mitx build FYI ;)
You forgot to include the OS.
hobo_fragginz
53
Sorry my bad, I'm using Windows 10 Home edition and I realise its actually a mini itx build. Just had a brain fart while typing.
So, I checked the bios and during idle (34 Celsius) and right after gaming (approx. 40 Celsius)
