Did you actually remove the graphics card from the PCI-Ex16 expansion slot? In most situations, if a card is present, the on-board graphics are disabled.
-Wolf sends
Of course man i make onboard default for pcie it doesn t work to i try to change monitor the sameAre you connecting to an HDMI input on your display?
-Wolf sends
The same dude 😥😔 i think my i-gpu is deadIf your graphics card is removed, your BIOS should automatically revert to integrated graphics. You should not have any need to make any changes there. Reboot with the graphics card installed, the display connected to the graphics card and go into BIOS. Reset BIOS to default. Save and exit. Shut down your system and remove the graphics card. Connect your display to the motherboard HDMI output and reboot your system.
-Wolf sends
Yeah sometimes when i plug pcie express gpu i meam my rx vega 56 monitor turn off and pc freezes randomlyMonitor disconnects when gaming
I ll try to get vga dvi cable and i ll seeWhile basic Windows drivers should work, have you installed VGA and/or Chip Set drivers from your motherboard manufacturer? If so, and the default settings are set in BIOS and the graphics card has been physically removed, then I cannot think of any other possibilities.
-Wolf sends
But hey maybe hdmi port of the mb is broken yeah bcs pc without gpu can't run yeh maybe it isWhile basic Windows drivers should work, have you installed VGA and/or Chip Set drivers from your motherboard manufacturer? If so, and the default settings are set in BIOS and the graphics card has been physically removed, then I cannot think of any other possibilities.
-Wolf sends
