so most of the games that I play lag (stutter/micro stutter) some games like Genshin Impact micro stutter from 60 fps to 57 fps but it stutters on the way. some games like Apex Legends have stutters that go from 144 fps to 120 fps, the game lags in the meantime. Far Cry 5 Stutters when I pick up items. if these issues are hardware related then the only limitation that I can think of that I have is the fact that my games are installed on a 1TB HDD and not an SSD. although I have to note that I did install CS:GO on my 120GB SSD (that I have Windows installed on) but that didn't seem to have fixed the issue. So before I jump to any conclusion and go buying an SSD, is it going to fix my issue?
also, I have played Apex, CS:GO and Genshin Impact on the lowest possible settings but that barely if at all helped.
Specs: RTX 2060, I7-10700k, 32 GB ram, 144hz 1080p. Windows 10
Temps: CPU: 60-85. GPU: 71 although for some reason on HWINFO64 it shows that my GPU has exceeded its thermal limit, therefore, lowered its performance, lag still happens when it doesn't show that. Please Help!
EDIT: EVGA SuperNOVA 650 G5, 80 Plus Gold 650W, Fully Modular, Eco Mode with FDB Fan, 10 Year Warranty, Includes Power ON Self Tester, Compact 150mm Size, Power Supply 220-G5-0650-X1. Condition is good and I got the PSU in 2020.
