Ok, so I think that this will be a good system, but I just wanted to make sure that it would all work well together. One of my main concerns is if the power supply will be enough. Even though I'm only buying one graphics card right now, some time in the future I might want to buy another and SLI them together. I want to make sure that this system will allow me to do that. Also, If there's anything else that you notice that I've overlooked, I would love it if you would tell me. Thank you SO much!
Case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066&cm_re=antec_300-_-11-129-066-_-Product
Motherboard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188049
Processor:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
Memory:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227365
Cooling:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
HDD:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073
Optical Drive:
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118030
Video Card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130441
Power Supply:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371021
That's it. Any help would be greatly appreciated!!!!
Case:
Motherboard:
Processor:
Memory:
Cooling:
HDD:
Optical Drive:
Video Card:
Power Supply:
