Question My PC is underpreforming, and it's driving me crazy.
Mar 16, 2023
11
So, i bought an RTX 3060 in August, and i started to notice that the performance of the pc is not as good as i toght. For example i have about 45-76 FPS At Fortnite, i can't play GTA V, BF V, Warzone and games like these. Before the 3060 i had a 750ti
Here are my specs:
CPU: i5 10400f (stock cooler)
GPU: Gigabyte RTX 3060 Eagle OC 12gb
Motherboard: AsRock H470 Phantom Gaming 4
RAM: Hyperx DDR4 16gb 3600mhz (single channel)
PSU: I have a 750w chieftec power supply (I cant remember the exact name of it sorry)
I tried so many fps boost guides, benchmarked everything i can, ran a memory diagnostic, tried DDU once, and i tried almost everything.
Keep in mind that i'm using V-Sync because i have a 1650 - 1050 Monitor as my main and i have screen tearing, but when i turn off the V-Sync it's still bad.
I don't know what's wrong with my pc i think of some driver, or system issue at least i hope.
Thank you for your time and effort to help me (It means a lot because i'm 16 years old and i don't have enough money to give it to experts.)
even if it makes your games look rubbish i would start by turning down all settings to minimum or off , next turn things up bit by bit to see what happens.
It is suprising how how much you can turn down some settings without noticing any difference
cpu/gpu temp and usage during the game?
how full is the ssd?
malware scan the system?
latest motherboard bios?
The temp seems fine on both of them.
I have 50gb on the ssd so its not full.
I don't have any malware i actually checked that one.
But the bios, i haven't actually updated it.
I tried these a couple of times but it seems like it doesn't helps.
Here are my specs:
To clarify, you have one stick of 16GB RAM? If so this is your biggest performance issue. Alawys use two sticks of matched RAM for best results.
Reactions: KyaraM
There's no way in hell that an RTX 3060 should be unable to play GTA V so there's definitely something wrong.
I would recommend running DDU and then re-installing the nVidia driver. If that doesn't work, then it's probably hardware problem with the card itself and I would recommend contacting Gigabyte about getting a warranty replacement.
You can download DDU >HERE<.
