[SOLVED] My RAM should be at 3200Mhz but only running at 2133Mhz
May 13, 2019
9
I recently bought new components (all new components are listed below other than graphics card, that was in my previous system) but my RAM is running at 2133 Mhz instead of 3200Mhz. I tried changing the speed alone in the BIOS but it wouldn't boot with anything higher than 2133Mhz. I'm unfamiliar with BIOS options so if there's something that needs to be changed in there, could you walk me through it? (Sorry I'm unfamiliar and making things harder for you) Any help is greatly appreciated.
Spec:
i7 9700K
ASUS ROG gtx 1060 at 6GB
ASUS ROG Strix B360-F
16GB Corsair RGB RAM at 2133Mhz (should be 3200Mhz)
