[SOLVED] Need a good 500 - 650W power supply
aviv05443894
36
Can anyone recommend me a good 500 - 650 power supply for a 295W drawing build?
I dont want to go cheap on the psu but I dont want to go too high either.
PC Tailor
Herald
Rough budget and location my friend?
Glad you've already decided not to go cheap! (You'd be amazed how many unstable and damaged systems we see because of this).
What is the exact spec of the rest of your system as power supply calculators are notoriously inaccurate.
aviv05443894
36
Budget is 40-80$ and location is Israel
my specs are -
Operating System
‏‏ Windows 10 Home 64-bit
CPU
Intel Core i5 6600 @ 3.30GHz
Skylake 14nm Technology
RAM
‏‏‎8.00GB Single-Channel Unknown @ 1066MHz (15-15-15-36)
Motherboard
Gigabyte Technology Co. Ltd. H110M-S2H-CF (U3E1)
Graphics
Generic PnP Monitor (1920x1080@60Hz)
GTX 1660 Super*
Storage
931GB TOSHIBA HDWD110 (SATA )
Optical Driver
HL-DT-ST DVDRAM GH24NSD1
also what is the difference between bronze and gold rated psu?
PC Tailor
Herald
Efficiency - gold is more power efficient than bronze. But doesn't necessarily mean better quality.
In most cases, you won't have a significant decrease in your power usage, the margins between efficiencies are pretty small.
If that is your build, then something akin to the Corsair CX above would be perfectly suitable, but i don't know how well priced these are in your location.
Do you have a particular online shop in mind that you could link?
aviv05443894
36
https://ksp.co.il/ make sure to choose the US flag if it's not already in English.
https://www.ivory.co.il/power_suplly.html this one is in Hebrew only but i dont think it that much of a problem.
also 1$ = 3.5 ILS. for easy calculation you can use this site https://www.hamara.co.il/ .
Thanks for your help
PC Tailor
Herald
The cheapest I honestly would recommend on the first site is the Corsair CX: https://ksp.co.il/?uin=40816&select=.1108..140.&txt_search=
The only other one I would potentially consider is the S12ii which is the same price: https://ksp.co.il/?uin=9814&select=.1108..140.&txt_search= but the CX is a clear choice when they are the same price.
i checked the Ivory site and the same quality appears to be more expensive - and I wouldn't recommend the nonrated Cooler Master MWE, or the VS Corsair series for example.
aviv05443894
36
Is this the same CX you recommended me before? if not which one is better?
PC Tailor
Herald
it will be 30$ cheaper if i order it from amazon u think i should? i dont mind getting it later because i order a new gpu as well so it will take time to arraive.
Thank you for your help and quick responds, really appriciate it!
It's no problem at all my friend! I simply have no life... :)
I would yes, but ensure that it is exactly the same CX model, as there are OLDER CX models that are not great. You can tell by the colour of the label.
Green label = old and avoid.
Grey label = 2017+ and good.
Following that, the CX grey label is a good quality PSU, that is great value for money in most locations. 5 year warranty and shouldn't cause an issue with your components :)
aviv05443894
36
sorry to bother you again but i dont know what to do..
I wanted to order the psu u recommended me - https://www.amazon.com/gp/product/B01MRW2K79/ref=ox_sc_act_title_2?smid=ATVPDKIKX0DER&psc=1
but i saw one with 650W for only 10$ more -https://www.amazon.com/gp/product/B01B72W1VA/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&th=1
and its semi - modular too. u think i should go for the 650W insted? its still cheaper than if i buy the 550W in my country
