Question Need an actual tech-god to help me solve this issue
bigbadnoob
Commendable
Oct 20, 2016
21
This is the weirdest problem i have ever encountered... NO tech-supporters from neither Origin or Windows have been able to help.. Even their so-called expert team that my case was escalated to...
I cannot log into www.origin.com anymore.. Since 2 days ago.. My PW is correct and it works fine when i log in on my macbook.. But on my Windows 10 PC (the one i play games from) i just cant log in !... PW is correct, Origin says nothing is wrong with my account.. I have tried disabling right about everything from anti-virus to firewall and every other third-party program.. I reset the router, flushed cache / DNS.. Did a bunch of tests, wiped my entire hard-drive and re-installed windows 10.
STILL DOES NOT WORK.... I cannot log into this website.. It is literally the most weird thing.. I could understand if it has something to do with the origin client on my PC, but i cannot even log into the website ! Again.. works fine on my macbook, Origin says everything is ok on their end.. Tried re-installing windows completely..
Seriously, does anyone have ANY clue what could cause this? Do i have to buy a new computer ? i spend like 1500 dollars on this setup just a couple of years ago 🙁
Please please help, will provide any information you need to help me...
I would worry that you have gotten a DNS hijack malware that is redirecting your "www.origin.com" to a fraud website and your password has been stolen. You get the "bad password" response because there is nothing behind the fake site.
Do a DNS lookup on your macbook and get the IP address of origin.com. Then try that IP address on your Windows box.
I will try that. sec !
On MAC (Where it is working fine)
Traceroute has started…
traceroute to e4894.e12.akamaiedge.net (23.78.37.112), 64 hops max, 72 byte packets
1 192.168.0.1 (192.168.0.1) 1.455 ms 0.958 ms 0.960 ms
2 10.116.26.1 (10.116.26.1) 16.637 ms 14.156 ms 41.286 ms
3 ae10-100.kh2nqe12.dk.ip.tdc.net (176.22.62.104) 9.285 ms 10.833 ms 10.734 ms
4 ae3-0.khk7nqp7.dk.ip.tdc.net (83.88.2.35) 21.378 ms 13.554 ms 9.776 ms
5 peer-as20940.khk7nqp7.dk.ip.tdc.net (195.215.109.35) 250.117 ms 601.854 ms 204.631 ms
6 a23-78-37-112.deploy.static.akamaitechnologies.com (23.78.37.112) 12.013 ms 11.356 ms 35.232 ms
On PC (where it is not working)
Tracing route to origin.com [104.77.213.177]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 15 ms 12 ms 13 ms 10.116.26.1
3 8 ms 9 ms 8 ms ae10-200.boanqe11.dk.ip.tdc.net [176.22.62.106]
4 10 ms 9 ms 8 ms ae3-0.alb2nqc1.dk.ip.tdc.net [83.88.14.157]
5 7 ms 10 ms 9 ms a104-77-213-177.deploy.static.akamaitechnologies.com [104.77.213.177]
Trace complete.
Is this as it should be or have i been hacked ?
what version of windows? what antivirus/malware software?
motherboard model? or how are you connecting to the internet? wifi/ethernet
Windows 10, no anti virus (had AVG before but completely wiped by hard-drive when re-installing windows) Motherboard Asus Z-370P , ethernet, have tried both wireless and ethernet no difference...
If it's some sort of glitch Windows/Origin/firewall/browser interconnection glitch that might take countless hours to stumble onto/ identify/ cure, it's helpful to remember that if you have a USB 3.0 flash drive installer media and a decently fast SSD, Windows can be installed in about all of 5 minutes these days... (I see your post says you reinstalled, but, was this a 'reinstall/keep my files/settings'?)
Reactions: rgd1101
Are you suggesting that i re-install windows ? because i have already tried that
try direct access to the modem and not thru the router?
Hmm how do i do that 😀? My router is plugged into the wall with a cable... I dont think i have a modem ? Im not even sure what that is to be honest.. wasnt that those things ppl had in 1998 where you couldnt use the phone while on the inter net :)?... But does it not seem unlikely that it is router problems since my macbook has no problem logging in (using the same router)?
