[SOLVED] Need help to build around my rtx 3090 for a 3D workstation
Dec 3, 2020
Hello and thanks for reading! First of all I am a novice in PC hardware, with that out of the way; I have got my hands on a RTX 3090 and need to quickly decide on what to build around it. If any helpful minds could chime in, I would be super grateful.
(I already own a RTX 3090 so the 2000$ budget is for the remaining parts)
  • Build focus: 3D GPU Rendering (Octane renderer + Cinema 4D)
  • Form factor: whatever keeps it cooler and more silent, but ATX seems approachable. Build requirements:
  • rtx 3090 compatibility
  • minimum 2 x16 slots for 2 GPUS (over 2 slots is ok too)
  • minimum 2 slots for M2 SSDs (maybe go for 1tb and expand later?) (over 2 slots is ok too)
  • 128gb ram compatibility (maybe go for 64 and expand later?) should be DDR4 atleast
  • Stronger and less cores for CPU
  • Mobo doesnt need wifi, but should have RAID support
  • Budget: 2000$ (about 1700€)
Kinda lost with all the options out there, just want something reliable and expandable in the future (RAM, NVMe M2 SSD and GPU wise), let me know if you have any ideas!
Thanks in advance
See if this is to your liking;
PCPartPicker Part List
CPU: AMD Ryzen 9 5900X 3.7 GHz 12-Core Processor (€613.77 @ PC Componentes)
CPU Cooler: Fractal Design Celsius S36 87.6 CFM Liquid CPU Cooler (€129.90 @ PCDIGA)
Motherboard: Asus ROG Strix X570-E Gaming ATX AM4 Motherboard (€315.00 @ Globaldata)
Memory: Corsair Dominator Platinum RGB 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory (€284.99 @ Corsair)
Storage: Western Digital SN750 500 GB M.2-2280 NVME Solid State Drive (€87.23 @ PC Componentes)
Storage: Western Digital Black SN850 1 TB M.2-2280 NVME Solid State Drive (€243.81 @ PC Componentes)...
Storage: Seagate BarraCuda 4 TB 3.5" 5400RPM Internal Hard Drive (€79.90 @ PCDIGA)
Case: Fractal Design Define 7 Compact ATX Mid Tower Case (€119.90 @ PCDIGA)
Power Supply: SeaSonic FOCUS Plus Gold 850 W 80+ Gold Certified Fully Modular ATX Power Supply (€139.90 @ PCDIGA)
Total: €2014.40
Generated by PCPartPicker 2020-12-04 03:29 WET+0000
Well, there's a lot of room for improvements, it's possible to water it down but I think the general idea is there for your workstation. Also, the cost of rams in your country are horrible.
Total: €2014.40
You're gonna have to tweak that. OP said "Around 1700 Euros" 😛
