I'm currently in the process of assembling my new system:
AMD Athlon 64 X2 4200+ (Manchester)
2GB OCZ DDR400 Platinum EL
DFI LanParty UT nF4 Ultra-D
2x120GB Seagate Barracuda 7200.7 (8MB cache, NCQ)
Sapphire X550 with 256MB memory
OCZ PowerStream 520W PSU
Thermaltake Armor (silver)
Now I'm almost finished, but I have some questions I need answered:
1) When installing the CPU, I accidentally removed a very small patch of the thermal compound. I did so with my fingernail, because, silly me, for some reason I was expecting the thermal compound not to have the patterns that it had (it had small ridges on top, regularly), so I for some reason tried to peel a layer off. I probably affected an area no bigger than 1mm x 1mm on the edge of the thermal compound before realising my stupid mistake. Will this bring me any problems? Should I get more thermal compound, get rid of the old one? I wasn't really expecting this to be any problem since it's very much on the edge, and it affects such a small area that, in the end, it will probably only worsen cooling by a very small amount. Would you all agree?..... Should I be worried?
2) When installing the heatsink/fan, I installed the damned thing 180 degrees rotated, which means nothing for cooling but means that my fan wire has to pass right over the fan (a few centimeters above it, actually). Isn't so bad, I guess.... Right? Or should I redo the whole heatsink/fan installation before powering up?...... :frown:
3) The rest was relatively trouble-free. All the other cables presented no problem whatsoever, because most would only fit in only one way, but I'm a bit puzzled with the front panel connectors for the thermaltake armor. In particular, there seems to be no way of telling each wire apart in the Power On/Reset/LED bundles, which could, apparently, be installed the wrong way. However, each connector does have a small triangle pointing down (sometimes with an S written above it) for one of the wires. Question is, how do I make any sense of this? I don't want to connect these wires the wrong way. The USB wires are 5-wire bundles which are also not 100% clear to me, but are nonetheless much more understandable.
Any help would be appreciated. It's my first time actually building a computer from scratch, so please allow for some stupidity of mine... I'm also kind of afraid to mess up - what if I did something to my CPU, for example?... 😱 It's not like it's a budget CPU...
<P ID="edit"><FONT SIZE=-1><EM>Edited by Mephistopheles on 09/24/05 09:20 PM.</EM></FONT></P>
