[SOLVED] Need motherboard with built-in WiFi for i7-9700
Netreo
44
5
4,535
I've been looking around for some motherboards that support i7-9700 right out of the box and also has WiFi capabilities. But it's just impossible to find anything without BIOS update requirement.
I looked at some motherboards that I'm interested and one of them is confusing me.
Link: https://www.gigabyte.com/lt/Motherboard/Z390-I-AORUS-PRO-WIFI-rev-10/support#support-cpu
Under CPU support List it mentions that i7-9700K works with F1 BIOS version but it also says that requires F5 version. And I don't get it....
Any suggestion would be appreciated.
And if it is impossible to get motherboard with WiFi w/o updating BIOS and buying additional CPU, is PCIe WiFi card a better choice?
Sorry for the long post in advance!
Different steppings:
P0 requires BIOS F1
R0 requires BIOS F5
I'd always recommend a PCIE WiFi card over on-board, but if you're looking at a Mini-ITX board, you don't have much choice if you intend to add a graphics card. I suppose you could go USB for WiFi on a Mini-ITX
-Wolf sends
Thank you for your reply.
I have one more question. This motherboard ASUS ROG Strix B365M-F Gaming and this PCIe WiFi card Asus AC88. Will they work together? Or is there going to be a compatibility issue?
