I just put my new build together and for some odd reason my monitor does not receive any signal from the Graphics card. I've swapped monitors and also graphics cards and yet the monitor still did not receive a signal!
I'm out of clues to what could lead to the problem.
My setup is:
Phenom 2 940
- Coolermaster V8
Asus M3N79-T Deluxe
OCZ Platinum Ed. RAM 4GB
Powercolor HD4870 PCS+ 1GB
OCZ ModXStream 600W Powersupply
Up to now I've tested the RAM, which works fine. I'm about to test the graphics card, I won't be able to test the CPU/motherboard...So I guess if the graphics card works, it must be one of those causing the problem. I'll post the result in a bit.
I hope that I don't have to RMA anything, so hopefully someone has a clue to solving this problem.
Any info/input is appreciated!
Thnx in advance!
- Shugs
My setup is:
Phenom 2 940
- Coolermaster V8
Asus M3N79-T Deluxe
Thnx in advance!
- Shugs
