Hi there,
I've been having issues with my GPU for some time now. All of a sudden one day my PC booted to a black screen. I was able to go into the BIOS and switch over to integrated graphics and everything works fine.
I've tried the usuals - reseating the card, trying it in a different PCIe port, updating drivers etc. but nothing seems to be working.
On the odd occasion I've been able to get a signal through it momentarily before Windows kills the driver and I get an error 43 in Device Manager.
I asked a local PC store to test the card and they said they can't get a signal from it which led me to believe that the card is dead. However, I tried another GPU in the MB which I know was working. I also can't get a signal through that card.
So at this point I'm not sure if my GPU is dead, or my MB / PCIe ports are acting up (btw I see the cards listed as being detected in the ports in the BIOS), or if they're both at fault.
I guess there's also the Power Supply, which I can't personally see as being an issue (the second card I tried didn't need an additional 8-pin it just runs from the power it gets from PCIe).
I'm reluctant to take it to a computer store. I have all sorts of mistrust of these places and would really like to diagnose the exact problem(s) myself.
Here's my build:
https://ca.pcpartpicker.com/list/gnrPXv
Any thoughts / ideas? Failing that, if I was to bite the bullet and purchase a new MB / GPU what would you get that would be good for gaming that's good value for money (doesn't need to be 4K)
Here's my build:
