Started playing Dying Light and Dishonored 2 today which I can run on High graphical settings and get around 100 FPS.
When I play these two games the CPU usage usually sits at around 90-100% and GPU usage at 95-100% which gives me horrible stuttering and input lag. But as soon as I turn all the settings down to VERY LOW the GPU usage drops to 50-65% and CPU usage stays at the same levels while the stuttering and input lag gets dramatically reduced.
I have always suspected that something is wrong with my CPU/MOBO... Does this finally prove that I should probably get it replaced? I appreciate all the help <3
UserBenchMark https://www.userbenchmark.com/UserRun/28139489
Here is a hardware graph that I got from MSI Afterburner with settings turned to High View: https://imgur.com/a/Bvpf5Tw
SPECS:
SPECS:
- I5 4690K
- GTX 1060 6GB
- MSI Z97 GAMING 5
- 2X8 GB HYPERX FURY
- SAMSUNG 860 EVO
- Corsair CX 600
