[SOLVED] NZXT Kraken m22 100c Temps
Heran
127
Hi All,
My NZXT Kraken m22 temps go high as 100c when playing games like RDR 2, Battlefield V. Valorant, and GTA V temps are around 80-85c. Could you please tell me how to overcome this? Please consider the below points.
  • My previous M22 started to produce a crackling noise and the warranty provided a new one.
  • I have a Lian Li O11 D XL, and I have mounted the radiator on top of the case since there is no other place this can be mounted.
  • I tried mounting on the rear of the case but the screw holes don't align with the case.
My PC specs:
i7 8700
16 GB RAM
EVGA FTW Ultra RTX 3080
Asus ROG String b360 F-Gaming
Is this due to the mounting position of the cooler?
Thanks in advance.
Poor QC - it's probably clogged. You overcome this by replacing it with something else.
NZXT Kraken M22, Msi MAG + MPG Coreliquid, and Fractal Design Lumen... all the same OEM: Apaltek. The Lumens only recently came out, but time will tell if they suffer from the same problem.
View: https://www.youtube.com/watch?v=9U_5aGf0G9Q
A MAG Coreliquid was taken apart at the 20:50 mark... nasty.
I believe this pump on the radiator design is very bad architecture. NZXT M22 is the worst. I got this new one a couple of weeks ago and already temps are high. Maybe it's best to move to a corsair cooler.
