Question OBS Recording (Too Much Bass)
I am trying out OBS to do recording, but the Audio Output Capture EQ is different from what I am hearing.
To be specific the bass is just too much. I tried to play with the VST (ReaEQ) but it didn't make much difference.
Is there anything I could do to capture the audio exactly the same from what I am hearing?
I am using Realtek HD Audio Manager from Strix Z270f.
I've got the exact same problem and have for years when using OBS. FFsplit, before it died, didn't do this. Not sure what to suggest other than trying to work around it by messing with your sound settings. With Razer Synapse for example, I have to turn off bass boost, sound normalization, and I can only mildly adjust the equalizer settings, or else it becomes overbearing when listening back on recordings or for my stream viewers.
