Question old cooling fan removal
Oct 18, 2023
6
Hi, i have a this old computer system for over a decade now though it was just sitting there collecting dust in my store room for like past 5-6 years. Today i finally decided to take it apart to see what's inside it (it doesn't turn on). i have removed everything very carefully except I can't really figure out how to remove this old intel cooling fan, it is a Intel A80852-001 cooling fan. im sure im supposed to find some type of screws but i cant see any? can anyone help me with removing this old cooling fan?
No screws, two white leavers move to opposite position and disengage plastic hooks from socket.
Caution, after all this time heat transfer paste is most probably dried and cooler practically glued to CPU so...
Caution, after all this time heat transfer paste is most probably dried and cooler practically glued to CPU so try to twist cooler left and right. in extreme cases you may need remove whole plastic fan holder and heat heat sink with a hair dryer.
View: https://imgur.com/a/5oRy8HA
Thank you for helping, i had to remove the plastic fan holder and then do some twisting but it came off 😆. Again thank you very much
Reactions: CountMike
