I'm helping a friend rebuild a machine, and was going to basically only reuse his case and power supply from a 3+ year old machine...case is similar to an Apevia X-cruiser case, with the power supply mounted at the top. When we were at Frys, the young man helping us told me something that concerned me, and caused us to buy a new Power supply that supports the eps standard vs. the old 420w that my friend's machine has in it, and I'm curious if you can help me understand if he was correct or just trying to sell us a ps...my friend's old ps is a 420w with a 20 pin and 4 pin connectors, not the current 24 plus 8 - we were told that using the 20+4 would eventually short out the mobo, and that we either needed adapters or a new ps, which is the route we chose to go - one other note here is that the new ps is a top-mounted exhaust vs. rear, and this old case has the ps at the top, so i'll have to vent it downward (shouldn't be a problem, right?). I guess that's a long way to this question - did we do the right thing by buying a new ps (cooler master extreme power plus 500w) to go with this new rig (Gigabyte MA785 GMT - UD2H with an Athlon II x4 620 processor, 4 gb of ddr3 ram will be the new specs). Using onboard video, so no big power needs there...
Any advice would be greatly appreciated - both on if we really need the new ps and assuming we do, if firing the fan downward into the case is a problem...
thanks for your advice - this is my first post, so I apologize in advance if I made a mess of how I'm supposed to lay things out.
