[SOLVED] Parts Sourcing (SLI Bridge)
Yacobino
27
Hello, I'm currently running 2 msi GTX 1080x on my msi g170 gaming m5 motherboard and I found the ONLY sli bridge that will fit (MSI 2Way SLI Bridge M) but everywhere I look it either says currently unavailable, or discontinued. If any of you guys can find me a link to buy one of these bridges it will be greatly appreciated
Thanks
And FYI, they make an M and L version of the bridge, L will not fit so I need the M version.
sadly no. They again have the L version which is not compatible with my mobo. I also tried taking the like of the bridge I need and just type .ca on the end but that doesn't work either. It's really easy to see if you look up images of the two side by side, you'll notice the M version connections are closer together. I was also looking at 1 slot spacing SLI bridges but those dont seem to exist either. Im currently just using 2 sli ribbons and it works just fine, but it just doesnt look the greatest
