[SOLVED] PC Build Help Needed!!
NomadACB
Commendable
Jun 21, 2021
38
21
1,535
Hi there everyone,
I am currently in the market for a PC Build and require your expert help! Not sure if this is the correct forum area for this so apologies if its not!
Anyway, my budget is £800 and I want it to be able to run smoothly while gaming but also have the ability to do some editing on the side!
I know this is the place for this sort of help as I have came here in the past and left happy with a plan.
Any help would be greatly appreciated!
Many Thanks!
Really Nice build. Really appreciate the help.
I have two questions if you don't mind?
Question 1: What other GTX Card would you recommend if we went a little downgrade on it if at all?
Question 2: What sort of build would you recommend for using software like Maya, Premiere, Vegas Pro, ect. Basically it would be for Editing and animating?
Cards are more expensive than gold right now. Only 6 left of this 1650 at the time of posting...
PCPartPicker Part List
Type|Item|Price
CPU | Intel Core i5-11400F 2.6 GHz 6-Core Processor | £159.59 @ Overclockers.co.uk
CPU Cooler | Deepcool GAMMAXX GTE V2 64.5 CFM CPU Cooler | £30.46 @ Scan.co.uk
Motherboard | ASRock...
Not a good time to build due to inflated prices. The card is available at the time of posting...
Type|Item|Price
CPU | Intel Core i5-10400F 2.9 GHz 6-Core Processor | £131.00 @ Amazon UK
CPU Cooler | Deepcool GAMMAXX 400 V2 64.5 CFM CPU Cooler | £20.63 @ Amazon UK
Motherboard | ASRock B560M Pro4 Micro ATX LGA1200 Motherboard | £98.64 @ CCL Computers
Memory | Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3000 CL15 Memory | £67.23 @ Amazon UK
Storage | Crucial P2 500 GB M.2-2280 NVME Solid State Drive | £51.77 @ BT Shop
Video Card | Gigabyte GeForce GTX 1660 SUPER 6 GB OC Video Card | £389.99 @ CCL Computers
Case | Fractal Design Focus G ATX Mid Tower Case | £30.64 @ Amazon UK
Power Supply | Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply | £64.98 @ Amazon UK
| Prices include shipping, taxes, rebates, and discounts |
| Total | £854.88
| Generated by PCPartPicker 2021-06-21 08:07 BST+0100 |
Reactions: NomadACB and Why_Me
Type|Item|Price
| Total | £854.88
Here's the exhaust fan for the case in your build. btw nice build.
https://www.scan.co.uk/products/120...50rpm-53cfm-fluid-dynamic-bearing-black-4-pin
Arctic 120mm Case Fan £4.99
Reactions: Hellfire13
Type|Item|Price
| Total | £854.88
With the proggy's you plan on using I'd look to the newer 11th gen. i5 11400F. It cost a little more and it runs a bit warmer but it natively supports 3200Mhz RAM and it's faster.
https://www.ebay.co.uk/itm/333991251027
EVGA GTX 1650 Super 4GB GDDR6 Graphics Card £289.99
https://www.scan.co.uk/products/int...reads-26ghz-44ghz-turbo-12mb-cache-65w-retail
Intel Core i5 11400F £149.99
https://www.scan.co.uk/products/dee...-single-tower-aluminium-fins-4x-heatpipes-int
DEEPCOOL GAMMAXX GTE V2 Black Cooler £24.98
https://www.ebuyer.com/743022-corsa...ram-3200mhz-c16-memory-kit-cmk16gx4m2b3200c16
Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3200MHz C16 £72.99
Type|Item|Price
Memory | Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory | £72.06 @ Amazon UK
Video Card | Asus GeForce GTX 1650 G6 4 GB Phoenix OC Video Card | £269.95 @ Amazon UK
| Total | £778.09
| Generated by PCPartPicker 2021-06-21 08:59 BST+0100 |
The above build should be fine for your editing workload given the budget.
Reactions: NomadACB
