[SOLVED] PC Build help/review
Apr 1, 2021
4
Hi there, I'm building a PC purely for using audio software at a high level. I need good processing power and good RAM. I have put a low GPU in as I can always upgrade later on down the line.
Do you guys have any advice or would you swap anything out to save more/squeeze more performance?
All help is appreciated :)
THE BUILD:
https://uk.pcpartpicker.com/list/pk4ty4
Your build will work as is.
Some thoughts:
No need for the gt1030 The 10700K included integrated graphics.
Suitable for all but high refresh gaming.
It can drive a 4k monitor@60hz via displayport.
From what I see, the new Z590 motherboards are no more expensive than their Z490 predecessors.
To get best performance, you need a better cooler to let the processor turbo up to the max.
Here is noctua's suitability guide for the i7-10700K:
https://ncc.noctua.at/cpus/model/Intel-Core-i7-10700K-416
For comparison, the AF 34 is probably similar to the NH-U12s.
Not bad, but not best either.
THE BUILD:
Hello there!!
You didn't mention your budget so it becomes difficult to suggest you something I would recommend you this especially if you earn money through your pc.
https://uk.pcpartpicker.com/list/LZnmp2
Some thoughts:
