Hello, first my setup!
MOTHERBOARD:
GIGABYTE GA-970A-DS3P
CPU:
AMD FX-8320 ( 8x 3500 Mhz ) Octocore
CPU-COOLER:
Scythe Mugen 4 SCMG-4000
RAM:
16GB DDR3 1600Mhz (Crucial Ballistix - Dual Channel)
GPU:
ASUS NVIDIA GTX 1050
HARDDRIVE:
128GB Solid State Drive (Crucial MX100)
PSU:
Corsair VS Series VS650
So, I have this setup for 6 years now and only changed my GPU during this time.
This last month i had some random crashes, first it started after i finished a game, then during a game and now even when i just log into windows!
I have changed my ssd with a hdd but that made it worse, i reinstalled windows but also did not work. I also switched the SATA cable but that did nothing.
Next I tried resetting my BIOS but that did nothing aswell, I was overclocking my CPU so thats why I did the reset, but did not work.
Next I tried Memtest86 with each memory stick I had, 1 by 1, with 1 stick it crashed 2min in the test so I thought I had found the problem, removed that stick but then my system crashed again!
I also have the latest GPU drivers installed, latest windows 10 updates.
I also checked my temps during my gaming and my CPU was around 40C and my GPU around 60C.
I also did Furmark for about 30min and then it crashed?
Atm when I start my computer I can game for around 1hour and then it crashes, I then turn off my PSU and w8 15min and then it works well again, if I dont turn off my PSU and just let it reboot, it instantly crashes when I log into Windows 10!
Long story short, is it time for a new PC or what do you guys think which hardware is causing these crashes? Thank you very much for reading my post! And thank you in advance for the help! Any help appreciated!
MOTHERBOARD:
CPU:
CPU-COOLER:
RAM:
GPU:
HARDDRIVE:
PSU:
