So for a while now, my PC has been having these weird... frame freezes and cuts - It affects everything.
Every 1-3 seconds, my mouse freezes for a split second, or an animation in a game with freeze on the last frame of the animation then kick back into the animation, or a video will constantly freeze frame (this one is hard to notice so does not bother me) - or if i have an animated wallpaper, it freezes for a split second constantly. I dont know whats causing it.
My specs are:
B450 Tomahawk
Ryzen 3700x
RTX 2070
750 watt gold PSU
3200 speed DDR4 ram (32gb)
2x 1080p 1ms 75hz monitors (byt for some reason they are messed up and only work at 60hz) :
wired and wireless mouse
I have made sure everything is seated and connected, i make sure everything is updated, drivers and windows. i have tried rolling back already - it seems my issue went away when i went to the 1607 version of windows during a factory reset, but then came back when i updated windows to any other version - i updated my Bios, all my temps stay at about 40-60c on GPU and CPU - averaging around 51 out of games, 67 in games - i can get 100-200 FPS on max settings in a lot of games, i generally run high/med settings though - but this issue still affects everything no matter the settings. my FPS also will randomly go from 230 fps to 10 fps for a second here and there also, wich is an effect of my issue i presume.
i want to fix this. i been dealing with it for so long, but these freezes/cuts are hurting my eyes at this point, they are bothersome and have made playing games, a pain and not playable.
i hope i can get some help to fix this, and understand what is causing it and why...
my system itself runs good. and it was running great for a while. but idk when this started happening. i been dealing with it for.... 7 months now about?
My specs are:
B450 Tomahawk
Ryzen 3700x
RTX 2070
750 watt gold PSU
