The PC refuses to boot after a shutdown, as in like it will start, the fans would be at 100% Speed for some reason and it will give me the CPU light.
The PC refuses to go past bios and eventually operating system.
The only solution that I've found to fix this is, after I turn off the computer, the CPU light turns on, and to turn it off, all I do is remove the display port from the GPU, that way the light turns off, and then I plug in the display port and only then turn it on and it will work, I can also know it will work as fans won't spin at 100% speed.
Only after finding this "temporary" fix I thought it's the GPU, so then I tried 3 more GPU's, same problem.
CPU Runs fine, did a 12 hour stress test.
I have no idea as to why it turns on and if there is a pattern that can be fixed.
z490 gaming x, latest bios.
10700K
RTX 2070
750W Gold
Win10
10700K
RTX 2070
750W Gold
Win10
