Intel celeron g550 2.60ghzWhat are your COMPLETE system specs?
it also has a huge beep sound!
It says no signal so I cant get to safe mode and its been 2 days since I got my gtx 750 ti I played with it for about 1 day and a half the only problem I had was random no signals to screen but if I turned off the pc and turned it on back it worked all fineThis is weird...
Do You see the mobo bios when You start a pc? If yes, try to run windows in safe mode and remove graphics drivers. Maybe it will help....
You mean Your motherboard or something else?
If it's a mobo, probably You did something wrong (did not put a card in pci-e slot correctly, didn't attach all cables properly or something like this - then the pc won't start at all)
I think this is a motherboard problem since it beeps and doesnt give power to mouse and keyboard because if it was the cable only the monitor wouldnt work, so I dont know exactly but I hope its not a problem with my graphics card1) Make sure that display cable (card <-> monitor) is inserted properly and stable. Make sure this is the only cable at the moment, plugged to Your graphics.
Make sure Your graphic is placed correctly in the pci-e slot and holds stable. (remove + insert again, use the screw to make it stable).
Inspect the pins in display cable, try to replace display cable if You can borrow some.
Make sure that Your graphics card has external power supply attached correctly (if it has pin connectors)
If the monitor cable is broken, signal can be disturbed, when You for example move Your desk a bit.
If that doesn't help:
2) Try with another video card, that You know it works.
If another card will be working fine, probably something happened with Your gtx 750ti.
If other card won't work and You did everything right - that might be mobo/pci-e slot failure. In this case, You can try another pci-e slot if You have two on the mobo.
Thank you for your replies but I dont know much about computer psu and things like that, I have to get the PC to a repair shop soon and see what the problem is.You should have a 2-digit display on Your mobo. Read the error code from it, check the mobo model, google what this error means.
There can be few reasons of mobo's "beeping", depending on the mobo, like:
-...many others
- ram brick inserted skew (not all pins connected)
- same with graphics
If it beeps, it's not totally dead and should return the error type.
Also there's a chance that it won't work on integrated graphics (motherboard display port for monitor), because it's set up in bios to external graphics. If so, You may try to reset bios. Maybe it will work in Your case. (not sure) Well, at least worth to try.
try to plug the monitor directly to mobo and reset bios (disconnect psu, use reset bios button or remove mobo battery)
But first - check the cables / connections / graphics as said in 1)
I dont understand what you mean here, like connecting monitor to mobo means connecting it to integrated? If yes I have tried it and still the same issue and I have no idea how to reset bios and Im scared if I remove this things I'll make it worse 😕try to plug the monitor directly to mobo and reset bios (disconnect psu, use reset bios button or remove mobo battery)
i assume that You do have an integrated graphics on Your motherboard+cpu setup. Then, You should be able to connect Your monitor directly to motherboard.I tried booting with me intel hd integrated still black
So I removed the mobo battery and put it back after 5 mins, connected the vga to my integrated and turned it on still the exact same thing same beep same no signal..i assume that You do have an integrated graphics on Your motherboard+cpu setup. Then, You should be able to connect Your monitor directly to motherboard.
Do that, take out your gtx off the pci-e slot, try to start. If it doesn't work, try to reset the motherboard bios settings as described above (use reset bios button on your mobo or plug off the psu, remove battery from the motherboard, wait and turn it on again). Then, after bios reset, it might work just fine with the integrated grahics.
However, if You have no idea what You do, it will be the best to take the unit to someone who does.
Did You disconnect power supply as well? Did You take out graphics from pci-e slot before doing that?So I removed the mobo battery and put it back after 5 mins, connected the vga to my integrated and turned it on still the exact same thing same beep same no signal..
Yes I did all but still no solution..Did You disconnect power supply as well? Did You take out graphics from pci-e slot before doing that?
Did You ckeck the monitor cable? (tried another one?)
Did You check all the connections from instruction above, as @clarkjd posted?
I sent my pc to the repair shop and they said it is just the RAM so you should force ot down and hear a click when you insert the RAM, so the RAM wasnt inserted correctly thats why the computer did warn me by the huge beep, thanks for your time guys!If You are sure that:
...so basically You are sure, that everything SHOULD work, the next thing You can do is to eliminate broken parts. I understand it might be hard if You don't have any spare parts, but if You can borrow some for a moment, it's worth to try:
- everything is connected properly on the motherboard,
- Your monitor cable and screen works fine
- Your ram bricks are properly inserted and all work fine
- Your graphic card is properly inserted in pci-e
- Your GTX 750ti external power connector is connected to the psu (if You have 6 or 8 pin connector on Your graphic card)
Then, if You still have no idea what's going on, it's the time to give up and take Your rig to computer service.
- replace the pci-e card with different graphics card, check if works (maybe some old one?) If You know it's working in another rig, but not in Yours, probably Your mobo or CPU is dead.
- put Your 750ti in another comp - check if it works with another rig. If it doesn't - the card is probably dead
- Connect another psu to Your setup - check if works. Maybe Your PSU is somehow damaged?
