Pioneer DVR-106 problems
xazos79
275
Hi all.
I recently got a DVR-106 dvd burner. The problem is that i can't get it to burn (simulation doesn't work either). It never gets passed the "Lead-In" part of the burn process. The error message i get is:
"Unspecified Recorder Error"
I tried putting the burner in my old pc and it worked.
Now, my newer pc has an EPOX 8kha+ in it. The IDETOOL utility has the mode for the burner set to "multi-word DMA Mode 2". I've tried to set it to "Ultra DMA mode 2" but it just remains as "Multi-word DMA Mode 2". I've tried connecting it with 80 and 40pin cables on both the primary and secondary channels. I'm currently at my wit's end. Does anyone have any suggestions? BTW, if it helps, i'll post the error log in a post straight after this one.
Cheers...
<P ID="edit"><FONT SIZE=-1><EM>Edited by xazos79 on 08/28/03 11:32 AM.</EM></FONT></P>
Error log:
Sam
1502-4240-1125-0482-1088-9784
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 29/01/2003 10:37:36 PM
Nero Version: 5.5.10.32 (Nero Express)
Recorder: <PIONEER DVD-RW DVR-106D>Version: 1.05 - HA 0 TA 1 - 5.5.10.32
Adapter driver: <viadsk> HA 0
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <PIONEER DVD-ROM DVD-116>Version: 1.09 - HA 1 TA 0 - 5.5.10.32
Adapter driver: <viadsk> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : ST380021A 3.19 viadsk Port 0 ID 0 DMA: ?
CdRomPeripheral : PIONEER DVD-RW DVR-106D1.05 viadsk Port 0 ID 1 DMA: ?
CdRomPeripheral : PIONEER DVD-ROM DVD-116 1.09 viadsk Port 1 ID 0 DMA: ?
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 767MB (785904kB)
Free physical memory: 490MB (502612kB)
Memory in use : 36 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
Wizard: On
27.8.2003
ISO compilation
8:24:36 PM #1 Text 0 File Isodoc.cpp, Line 7576
Iso document burn settings
Determine maximum speed : FALSE
Simulate : TRUE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
8:24:36 PM #2 Text 0 File Reader.cpp, Line 115
Reader running
8:24:36 PM #3 Text 0 File Writer.cpp, Line 125
Writer PIONEER DVD-RW DVR-106D running
8:24:36 PM #4 ISO9660GEN -11 File geniso.cpp, Line 4571
First writeable address = 0 (0x00000000)
8:24:36 PM #5 Text 0 File Burncd.cpp, Line 3736
Turn on Disc-At-Once, using DVD media
8:24:36 PM #6 Text 0 File ThreadedTransferInterface.cpp, Line 672
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 2296224 (2296224) = #2296224/510:16.24
relocatable, CD pos for caching/writing not required/required, no patch infos
8:25:07 PM #7 Text 0 File DlgWaitCD.cpp, Line 222
Last possible write address on media: 2298495 (510:46.45)
Last address to be written: 2296223 (510:16.23)
8:25:07 PM #8 Text 0 File DlgWaitCD.cpp, Line 227
Write in overburning mode: FALSE
8:25:07 PM #9 Text 0 File DlgWaitCD.cpp, Line 1679
Recorder: PIONEER DVD-RW DVR-106D, Media type: DVD-R
Disc Manufacturer: PRINCO -
Disc Application Code: 64, Disc Physical Code: 193
8:25:07 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 824
Prepare recorder PIONEER DVD-RW DVR-106D for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD fixated
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 408006656
8:25:07 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 672
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2296224 blocks [PIONEER DVD-RW DVR-106D]
8:25:07 PM #12 Phase 24 File dlgbrnst.cpp, Line 1655
Caching of files started
8:25:07 PM #13 Phase 25 File dlgbrnst.cpp, Line 1655
Caching of files completed
8:25:07 PM #14 Phase 32 File dlgbrnst.cpp, Line 1655
Simulation started at 1x (1,380 KB/s)
8:25:09 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 1978
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
8:25:09 PM #16 Text 0 File DVDR.cpp, Line 1421
Recording mode: Sequential Recording Mode
8:25:09 PM #17 Text 0 File Mmc.cpp, Line 18003
Set BUFE: supported -> ON
8:25:09 PM #18 Text 0 File DVDR.cpp, Line 1535
Start write address at LBA 0
DVD high compatibility mode: Yes
8:25:11 PM #19 Text 0 File Cdrdrv.cpp, Line 7877
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: 10.08 Mbps (2 h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
8:25:14 PM #20 Text 0 File Writer.cpp, Line 316
20:25:14.846 - PIONEER DVD-RW DVR-106D : Queue again later (Intervall : 47msec)
8:25:40 PM #21 SCSI -500 File Cdrdrv.cpp, Line 1416
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x03480000
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x03 0x10 0x00 0x00 0x10 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
8:25:40 PM #22 Text 0 File Writer.cpp, Line 453
20:25:40.783 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 32768 Bytes
8:26:26 PM #23 Text 0 File Writer.cpp, Line 442
SCSI-Layer send CDRERR_BUFFER_TO_BIG to writer
8:26:26 PM #24 Text 0 File Writer.cpp, Line 453
20:26:26.979 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 30720 Bytes
8:26:27 PM #25 Text 0 File Writer.cpp, Line 424
Writer-Buffer for PIONEER DVD-RW DVR-106D reduced to 30720Bytes
8:26:29 PM #26 Text 0 File Writer.cpp, Line 453
20:26:29.954 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 28672 Bytes
8:26:30 PM #27 Text 0 File Writer.cpp, Line 316
20:26:30.004 - PIONEER DVD-RW DVR-106D : Queue again later (Intervall : 47msec)
8:26:30 PM #28 Text 0 File Writer.cpp, Line 453
20:26:30.004 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 26624 Bytes
8:26:30 PM #29 Text 0 File Writer.cpp, Line 453
20:26:30.054 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 24576 Bytes
8:26:30 PM #30 Text 0 File Writer.cpp, Line 453
20:26:30.094 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 22528 Bytes
8:26:30 PM #31 Text 0 File Writer.cpp, Line 453
20:26:30.144 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 20480 Bytes
8:26:30 PM #32 Text 0 File Writer.cpp, Line 453
20:26:30.194 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 18432 Bytes
8:26:30 PM #33 Text 0 File Writer.cpp, Line 453
20:26:30.234 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 16384 Bytes
8:26:30 PM #34 Text 0 File Writer.cpp, Line 453
20:26:30.284 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 14336 Bytes
8:26:30 PM #35 Text 0 File Writer.cpp, Line 453
20:26:30.334 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 12288 Bytes
8:26:30 PM #36 Text 0 File Writer.cpp, Line 453
20:26:30.384 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 10240 Bytes
8:26:30 PM #37 Text 0 File Writer.cpp, Line 453
20:26:30.424 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 8192 Bytes
8:26:30 PM #38 Text 0 File Writer.cpp, Line 453
20:26:30.474 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 6144 Bytes
8:26:30 PM #39 Text 0 File Writer.cpp, Line 453
20:26:30.524 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 4096 Bytes
8:26:30 PM #40 Text 0 File Writer.cpp, Line 453
20:26:30.564 PIONEER DVD-RW DVR-106D : WriteBuffer reduced to 2048 Bytes
8:26:30 PM #41 SCSI -31 File Cdrdrv.cpp, Line 1416
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x02264000
Status: 0xE6 (0x0E, SCSI_BUFFER_TO_BIG)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x03 0x10 0x00 0x00 0x20 0x00 0x00 0x00
8:26:30 PM #42 Text 0 File Writer.cpp, Line 446
Recorder-Buffer cannot be reduced any more
8:26:30 PM #43 CDR -31 File Writer.cpp, Line 333
8:26:30 PM #44 Text 0 File ThreadedTransfer.cpp, Line 222
all writers idle, stopping conversion
8:26:30 PM #45 Text 0 File ThreadedTransfer.cpp, Line 216
conversion idle, stopping reader
8:26:30 PM #46 SCSI -31 File Cdrdrv.cpp, Line 1416
Sense Code: 0x26
Sense Qual: 0x02
8:26:30 PM #47 CDR -31 File WriterStatus.cpp, Line 163
8:26:30 PM #48 TRANSFER -24 File WriterStatus.cpp, Line 163
Could not perform end of Disc-At-Once
8:26:34 PM #49 Phase 34 File dlgbrnst.cpp, Line 1655
Simulation failed at 1x (1,380 KB/s)
8:26:34 PM #50 Text 0 File Scsicmd.cpp, Line 406
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=5.3.1.158, size=23420 bytes, created 16/06/2003 12:37:31 AM
File 'Drivers\viadsk.sys': Ver=3.1.1, size=49644 bytes, created 16/11/2000 2:31:00 AM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
