Hi!
I'm lost in a maze here.
A couple of days ago I got my new Barebone system. ASUS T3-P5G31A. Sensor chipset is IT8720F. Wonderful, neat and minimalistic. After XP install I quickly installed Speedfan to make sure I hadn't messed anything up. This lead to an unpleasant surprise. Temp1 was showing at 84 degrees Celcius. I rebooted and entered BIOS. The HW Monitor only showed two temps: CPU & MB. Both where fine (CPU 38c / MB 28c, sort of). I revisited Windoze. Same crazy 82 reading in Speedfan. I posted on some tech board for answers.
They suggested that the reading was not to be taken seriously, probably just an unattached sensor, they tended to show bogus values on and till. Hmm, ok ok. Well. I ran some CPU stress tests. The funny thing is that this particular sensor then raised. It maxed out on 90 degrees celcius, after around 15min of stress test. Mad! I thought to myself "If this is just an unattached slash bogus fake sensor, how come it reacts "logical" to load?", and re-posted. Someone then said that it would prolly be the north bridge, which was nothing to worry about 'cuz they could withstand well over 100 degrees celcius. I was also adviced to try other software than Speedfan.
So, I tried also HWMonitor, aswell as EVEREST, SIW and CoreTemp. All apps grab the same value for this particular sensor. Although they name it differently. In Speedfan it's "Temp1", in EVEREST it's "Aux", and in CoreTemp it's "Tj. Max".
Now. I just caught some very interesting reading. The term "Tj. Max" is what called my attention. I made some research and, well, I'm not sure but (from what I read in article below) it seems that Tj. Max is actually referring to the "auto-shutdown-point". If this is the case, it would really be nice, huh? Then I could just "let go" of that sensor value, right?
http://www.tomshardware.co.uk/forum/page-243998_11_0.html
Please give me a shed of light on this one, or I will stay sleepless forever.
Regards~
Regards~
