PLEASE HELP! SPACE PROBLEMS WITH CASE! (im serious guys and DONT think im a troll)
sixsamuraisoldier
426
Ok, so here's the thing, i would like to get the cooler master haf x, HOWEVER, im worried i wont have enough space. (as you can see, i have 4 gpus and 2 psus)
Here's my build:
CPU: Haswell (free)
GPU: EVGA GeForce GTX780 SuperClocked w/EVGA ACX Cooler 3GB GDDR5 384bit, DVI-I, DVI-D, HDMI,DP, SLI Ready (03G-P4-2784-KR)
(FOUR of these) ($2640)
Case: Cooler Master Haf X w/ SuperSpeed USB 3.0 ($180)
Motherboard (modify for extra RAM and other things) : ASUS Maximus VI Extreme (when it comes out) ( expected pricing : $400)
Monitor: Asus PB278Q 27" Class Widescreen PLS LED Monitor - 2560 x 1440, 16:9, 80000000:1, 5ms, HDMI, DisplayPort, DVI, Energy Star ($650)
SSD : Samsung Electronics 840 Pro Series 2.5-Inch 512 SATA_6_0_gb Solid State Drive MZ-7PD512BW (TWO of these) ($940)
HDD: Western Digital WD1002FAEX Caviar Black 1 TB SATA III 7200 RPM 64 MB Cache Internal Desktop 3.5" Hard Drive ($90)
Power Supply: Thermaltake Toughpower 1500W ATX12V 2.3 24PIN Power Supply Active PFC 80PLUS Silver SLI CF 135mm Fan($300)
RAM: Corsair Vengeance 16GB (2x8GB) DDR3 1600 MHz (PC3 12800) Desktop Memory (CML16GX3M2A1600C10) (TWO of these) ($240)
Operating system: Windows 7 Ultimate 64-bit (free)
CPU Cooler: Thermalright Silver Arrow SB-E Extreme Dual Fan Universal CPU Heatsink ($100)
Thermal Compound Paste: Arctic Silver 5 High-Density Polysynthetic Silver Thermal Compound AS5-3.5G - OEM ($10)
HDMI: AmazonBasics 2-Pack, High-Speed HDMI Cables 6.5 feet -- Supports Ethernet, 3D, and Audio Return [Newest Standard] ($10)
HDMI to DVI: AmazonBasics HDMI to DVI Adapter Cable (9.8 Feet/3.0 Meters)
Intel Gigabit CT PCI-E Network Adapter EXPI9301CTBLK ($30)
Mediabridge Networking Cat5e Patch Cable - (15 Feet) - Red RJ45 Computer Patch Cord ($6)
IC Diamond 24 Carat Thermal Compound - 4.8 gram ($15)
2.5-inch SSD/Hard Drive to 3.5-inch Bay Plastic Tray Mount Adapter Kit (TWO of these) ($14)
Intel 4965AGN Next-Gen Wireless-N PCIe Mini Card Network Adapter - Mini PCI Express - 300Mbps ($9)
Razer Naga Special Edition - Molten (RZ01-00280500-R3) ($70)
Corsair Vengeance K70 Mechanical Gaming Keyboard - Black Cherry MX Red (CH-9000011-NA) ($130)
CM Storm Skorpion - Gaming Mouse Bungee with Flexible Mouse Cord Arm (SGA-2000-BKNX1) ($20)
Build Your Own PC Do-It-Yourself For Dummies [Paperback] ($20)
HDE® USB 3.0 Male to Female Cable 1.5m 5ft (Backward Compatible with 2.0) ($5)
Norton 360 2013 - 1 User / 3 PC ($25)
Crysis 3 ($40)
Plantronics GameCom 780 Surround Sound Stereo PC Gaming Headset - Frustration Free Packaging ($55)
ASUS Xonar DGX PCI-E GX2.5 Audio Engine Sound Cards ($40)
League Of Legends Logo Mouse Pad ($9)
Phobya 24 Pin 2-Way PSU Starting Cable (Black Sleeved) ($20)
Add2PSU Multiple Power Supply Adapter ($20)
Seasonic PLATINUM-860 ATX 860 Power Supply ($200)
Logitech Surround Sound Speakers Z506 (980-000430) ($80)
mPCIe Combo Card ($30)
THANKS IN ADVANCE! :)
Fulgurant
585
Yeah, you know -- normally I wouldn't question someone's personal choice to do what he wishes with his money, but then I see this on the OP's list of ordered parts:
"Build Your Own PC Do-It-Yourself For Dummies [Paperback] ($20)"
And I have to wonder whether he knows what he's buying, like at all.
Fulgurant
585
Ok, so my last post was a little harsh and content-free, so here's straight-faced answer to the OP's posted build: your PSU is too weak. The four graphics' cards, alone, will consume a max of about 1072 Watts on the 12V rail.
GTX 780 Power Consumption
Also, if front-facing USB 3.0 ports are your concern, you can buy a HUB that will slot into one of your drive bays.
sixsamuraisoldier
426
so it doesnt leak
sixsamuraisoldier
426
my two psus together support about 2350 watts :)
sixsamuraisoldier
426
whats a hub?
endeavour37a
Perhaps you missed this part.........
They are also claiming solid SLI scaling. As measured with FCAT, greater than 175% SLI scaling appears pretty common. Speaking of SLI, like the TITAN before it, official support will extend only to tri-SLI. That’s ok because quad GPUs from either camp are known to scale very poorly, but so you know, there won’t be official support for quad-SLI.
Just thought you should know, that is a lot of money...
Traildriver
587
So let me get this right... you are using 2 PSU for a total of 2360W available? In North America and a 120V household system that will pull a theoretical 19.5 amps of power. You have a problem. Normal house wiring has a practical limit of just over 12 amps on a circuit with a breaker set to 15 amps. (Note: 1500W divided by 120V equals 12.5A, the max practical load on a single circuit rated at 15A)
Just how do you plan to power this beast up without the wiring in your walls overheating. And plugging one PSU into each half of an outlet is still putting the total load on one wire in the wall and one breaker.
Your unit is not practical unless you are willing to run new house wiring with 2 paired breakers (such that if one 15 A circuit trips then the other 15A trips as well). And all your monitor(s), scanner(s), printer(s), modem, desk lights, room lights, etc. need to be powered separately from the PC circuit because they all draw current.
You need to do a rethink of the whole setup.
sixsamuraisoldier
426
