Please Help! UNKNOWN Device USB
clayton
240
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I'll try my best to explain my problem and see if anyone here can explain
this because I stumped!
I brought a DELL 8300 in April this year and last month I noticed in Device
Manager under the USB section, there was an entry in there about unknown
device which I tracked down to being the Brother printer, so I replaced the
cable and it still showed up as unknown device, so I changed it to another
USB port and everything worked fine, so I plugged in another USB device
where the printer was and that showed up as unknown and a message showing
unknown device bla, bla, bla, so I rang Dell and said my USB port is faulty
and they send a replacement MB out which I then decided to do a clean
install and all was well until today when I plug in my phone which was
configured to the USB port and it showed up as unknown again (same port) I
unplugged the phone from the cable and plugged it in again and now it's
working fine, Not sure when it will say unknown again....
It maybe a SP-2 issue, I don't know, can someone shed some light on my
problem please, motherboard again??
Thanks
Just to add to this, the Unknown device under the USB section did not have
any yellow ? beside it, it was like it was installed correctly but after
seaching google I came up with another issue after following these steps.
1. Click Start. Click Run. Type cmd and press OK.
2. Type "set DEVMGR_SHOW_DETAILS=1" (without quotation
marks) and press Enter.
3. Type "set DEVMGR_SHOW_NONPRESENT_DEVICES=1" (without
quotation marks) and Press Enter.
4. Type "start devmgmt.msc" (without quotation marks) and
click press Enter.
Then I found a unknown device with the Yellow ? beside it and it was greyed
out, I removed it and refreshed the device manager which it configured a
BASE SYSTEM DEVICE, weird
"Clayton" <claytonbNOSPAM@xtra.co.nz> wrote in message
news:eG6nKs1tEHA.1400@TK2MSFTNGP11.phx.gbl...
> Device Manager under the USB section, there was an entry in there about
> unknown device which I tracked down to being the Brother printer, so I
> replaced the cable and it still showed up as unknown device, so I changed
> it to another USB port and everything worked fine, so I plugged in another
> USB device where the printer was and that showed up as unknown and a
> message showing unknown device bla, bla, bla, so I rang Dell and said my
> USB port is faulty and they send a replacement MB out which I then decided
> to do a clean install and all was well until today when I plug in my phone
> which was configured to the USB port and it showed up as unknown again
> (same port) I unplugged the phone from the cable and plugged it in again
> and now it's working fine, Not sure when it will say unknown again....
> Thanks
After replacement of the motherboard and install of XP, did you reinstall
the motherboard chipset drivers?
Cari (MS-MVP) Windows Client - Printing/Imaging and Hardware
www.coribright.com
news:ut6IW71tEHA.2876@TK2MSFTNGP14.phx.gbl...
> click press Enter.
> greyed out, I removed it and refreshed the device manager which it
> configured a BASE SYSTEM DEVICE, weird
>> another USB device where the printer was and that showed up as unknown
>> and a message showing unknown device bla, bla, bla, so I rang Dell and
>> said my USB port is faulty and they send a replacement MB out which I
>> then decided to do a clean install and all was well until today when I
>> plug in my phone which was configured to the USB port and it showed up as
>> unknown again (same port) I unplugged the phone from the cable and
>> plugged it in again and now it's working fine, Not sure when it will say
>> unknown again....
>> Thanks
Yes I did, Intel chipset v 5.00.1012 from the dell website
"Cari (MS-MVP)" <Newsgroups1@coribright.com> wrote in message
news:OAv8bc5tEHA.2452@TK2MSFTNGP10.phx.gbl...
> www.coribright.com
>> have any yellow ? beside it, it was like it was installed correctly but
>> after seaching google I came up with another issue after following these
>> steps.
>> click press Enter.
>>> explain this because I stumped!
>>> changed it to another USB port and everything worked fine, so I plugged
>>> in another USB device where the printer was and that showed up as
>>> unknown and a message showing unknown device bla, bla, bla, so I rang
>>> Dell and said my USB port is faulty and they send a replacement MB out
>>> which I then decided to do a clean install and all was well until today
>>> when I plug in my phone which was configured to the USB port and it
>>> showed up as unknown again (same port) I unplugged the phone from the
>>> cable and plugged it in again and now it's working fine, Not sure when
>>> Thanks
