PLEASE HELP! When Installing My GTX 960, No Signal Found on my monitor
Page 4 - Seeking answers? Join the Tom's Hardware community: where nearly two million members share solutions and discuss the latest tech.
InfernalPhantom
Commendable
Jun 8, 2016
77
So I got a gtx 960 strix 4 gb and I installed it correctly with the 6 pin connected. I plug in it into my monitor (via VGA with the VGA-DVI converter) and power the system, no post beeps and every fan is spinning EVEN the video card's. However the monitor does not get a signal. (Btw my old video card recognizes the monitor but not the new one). Can someone please help me fix this problem, Thanks!
New Video Card:
http://
My PC (Switching the GTX 645):
http://
Wow this thread is off the rails.
First off drivers don't matter, if you don't even see the BIOS then its a hardware problem.
Secondly, that PSU is more than fine, and I saw you asked about this in the HP forums, they all have no clue what they are talking about.
Third you don't need to disable onboard graphics, thats a waste of time, its already disabled and even if it wasn't you had a GPU in there before. Don't remove those tabs, you don't need to.
Fourth BadActors suggestion is likely the issue, did you follow that exactly?
And finally, I don't like those converter cables, many times they are the source of the problem, can you use an HDMI or anything else to make a direct connection to your monitor or another monitor?
No idea yet but considering how low power, probably way less than 40
I have a similar problem.So I just recently cleaned my pc. Unplugged everything to make sure i didnt shock myself before working in it. I Dusted it out and made sure everything was fine. I powered it on and i did not get a signal on my moniter. The fans powered on and then slowed to a stop. I checked everything and it is all plugged in correctly. Its a new card, not really even a year old. The only thing i can think of doing is removing it and checking to see if the bios is derecting it. Also no beep from it upon start up as well.
This post is a year and a half old and already solved. Post a new thread with your full system specs and details on your issue. Thread closed.
