A couple days ago, I spilled a cup of water on my computer while it was running [stupid, I know] I immediately unplugged the power and I did not hear any error noises or problems before unplugging it. The majority of the water was on the bottom of the case, under the GPU and there was a small amount of water on the motherboard.
I dried it all off with a cloth, then I let my pc dry in front of a fan for about 3 days before i powered it on and i was pretty sure there was no water anywhere inside it from visual inspection beforehand and rotating of the case.
My PC worked completely fine for about a day, but then I started getting problems. My pc started randomly turning off then rebooting whenever I'm playing a game. It runs perfectly fine until the screen suddenly turns black and then it restarts.. I inspected the pc and there is seemingly nothing wrong with it. I want to know which part of my pc is damaged and how to find out. Im really hoping its not my motherboard, because its the most expensive thing I own and it was a gift.. I'm thinking its a GPU or PSU problem but I'm not completely sure, is there any software i can install or any tips to help me diagnose my parts and figure out which is damaged?
