[SOLVED] Power cable for GTX 1070 G1 Gaming
guymarshall
549
4
11,015
I have a Dell Precision Tower 5810 with a 685W PSU and it has an external power board to power the CPU power, PCI etc. This is the link to the board: https://www.ebay.co.uk/itm/362512033183. I noticed on the board an 8-pin connector that is split up into 2x 6-pins, but the graphics card I want to get needs an 8-pin.
I am wondering if I can:
  • use the 6-pin and put it into the 8-in on the graphics card without the 2 extra pins
  • buy a 6-pin to 8-pin adapter and use one of those 6-pins to power the 8-pin into the card
  • buy an 8-pin to 8-pin male to male extension (can't find one anywhere though)
  • use an existing 8-pin to 8-pin+6+2pin from my old Strix 970 to power the card?
I am really confused with the whole 6-pin vs 8-pin because 50% people say 6-pin can also deliver 150W and the other 50% say it is dangerous to do that and should instead use 8-pin. If somebody could suggest the best way forward I would be forever grateful :)
Here are the links to photos of the board, power connectors and cables:
No problem! The motherboard has an 8-pin to dual 6-pin cable. I have an 8-pin to 6+2 pin from another pc. For some reason on that 8 to 6+2 pin adapter, the 8-pin does not fit into the 8-pin on the motherboard. The shapes of the 8 holes are slightly different so it won’t go in. 🙁
The 8 pin to 6+2 is obviously off a different make of computer or PSU, different manufactures like to use their own sockets....it insures that you buy your cables from them :)
Like I said earlier, most cards that have an 8 pin will come with a 2x6 to 8 pin adaptor in the box with the card.....if you don't have one, your best bet is to buy one as it's the easiest solution to your problem.
You need all 8 pins to be connected, so you can't just plug in a 6 pin. This means you either need an 8 pin to 8 pin, but you say you can't find one. So your best option would be a 2x6 pin to 8 pin, many cards come with these in the box.
Thank you for the fast reply! So would I plug the 2+6 pin into the board and the 8 pin into the graphics card or the other way around?
Sorry for late reply, got busy. What plug/s do you have? I thought you had two 6 pins from an 8 on the board. You mentioned a 6+2, which is not the same as 2x6. If you have a 6+2 plug, then it's both a 6 or 8 pin for the card, and that's why it's a good design as the same plug can do both.
Assuming you only have two 6 pin plugs, then they both go into the 2x6 to 8 pin adaptor and the resulting 8 pin goes into the card.
Is there any adapter between the 8-pin on the motherboard and the 8-pin to 6+2 that comes with graphics cards? Thanks again :)
