Print Spooler always running 100%
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
I have XP/SP2 Home ed. with an Epson 780 inkjet. When I tried to connect a
new laptop (Same OS) to the wireless network to share the printer, the
spooler now runs 95+% of the CPU.
I've attempted to uninstall all print drivers and epson monitors, the print
service continues to hog the CPU. Any thoughts??
Uninstall and reinstall corrrectly...
http://www.coribright.com/Windows/Article%20One.htm
Cari (MS-MVP) Windows Client - Printing/Imaging and Hardware
www.coribright.com
"RI_Updates" <RIUpdates@discussions.microsoft.com> wrote in message
news:CB311414-1E16-477B-81B9-36F11F0FFBCD@microsoft.com...
> print
Hi,
I would advise a manaul removal of the printers from the registry. Please
see steps below:
Steps:
1. Click Start, click Run, type regedit and click OK.
2. Delete all the contents of the following registry keys:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Print\Environments\WindowsNT x86\Drivers\Version-2
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Print\Environments\WindowsNT x86\Drivers\Version-3
• HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Print\Printers
3. Check the following registry key for third-party monitors. Remove any
non-default monitors:
• HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors
ï?¶ The default port monitors are:
AppleTalk Printing Devices (When Services for Macintosh is installed)
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT Fax Monitor
4. Check the following registry key for third-party print providers. Remove
any non-default print providers:
• HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Providers
ï?¶ The default print providers are:
Internet Print Provider
LanMan Print Provider
5. Delete the printer driver files:
• Delete all drivers from the
%SystemRoot%\System32\Spool\Drivers\W32x86 folder.
6. Restart Windows.
7. Re-install the printer drivers.
8. Test to see if you are able to print.
Regards,
