Hi , I just bought an Samsung 144hz LC27FG73FQUXEN , and later when I turned on this happened. It worked again after I turned it off and on after. Should I return it ?
View: https://imgur.com/B6dOs9y
I'm currently using display port, the problem appeared just one time till nowTry a different cable or port and see if the issue repeats.
It appeared only once , but windows wasn't installing anything, I installed the drivers hours before that and the pc restarted after.If appeared only once, when was connected and Windows was installing drivers and configuring the display then you shouldn't concern with it.
Windows 10 could install drivers and updates in the background and you will might not even notice unless it requires a reboot.It appeared only once , but windows wasn't installing anything, I installed the drivers hours before that and the pc restarted after.
Not really, my updates are paused.Windows 10 could install drivers and updates in the background and you will might not even notice unless it requires a reboot.
I do hope you used either Local Group Policy Editor or the Registry to pause drivers update, otherwise they will sip thru on 1809 or later Windows 10 versions.Not really, my updates are paused.
