Hey all, I have a question about a new CPU I bought, an Intel Quad Core Q9550 (replacing my trusty old E6750).
For some reason, it's speed is only 2,23GHz: it says so during POST (Cores 4 @ 2,23GHz), as well as in Windows (CPU-Z and Sandra Lite). I noticed that the bus speed is only 266MHz (resulting in a Rated FSB of 1067MHz), so I think that might explain the slow CPU speed: 266MHz x 8,5 = 2,23GHz, whereas it should be 8,5 x 333MHz = 2,83GHz (Rated FSB 1333MHz).
All settings in the BIOS are defaulted (Auto), except the boot order and two power saving settings (SpeedStep and C1E), which are disabled). I've tried playing with manual settings (FSB Frequency, DDR speed, stuff like that), but so far to no avail, so everything's back to auto for now.
My question is what I need to do to have my CPU/bus speed operating at normal speeds? I'm not interested in overclocking my system (at least not for the time being - first want everything to run the way it should be) btw., so all I need is some tips on how to fix this problem in order to get everything running at stock speeds.
System specs:
- Asus P5K motherboard P35 chipset (BIOS version 1201; is most recent)
- Intel Q9550 (stock cooler)
- 6GB RAM DDR2 (2GB kit OCZ Platinum XTC + 4GB kit OCZ Platinum XTC)
- EVGA Geforce GTX260 SC 216 55nm.
- Seagate Barracuda HDD 320GB S-ATA
- Seagate Barracuda HDD 160GB IDE
- Chieftec 560 Watt PSU
- Cooler Master Centurion 5
CPU-Z screenshot 1:
CPU-Z screenshot 2:
CPU-Z screenshot 3:
Sandra Lite screenshot:
If more info/screenshots are needed, just let me know.
Thanks in advance!
System specs:
CPU-Z screenshot 1:
CPU-Z screenshot 2:
CPU-Z screenshot 3:
Thanks in advance!
