Quick help picking a Motherboard...
wirelessfender
273
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131219
Do I have this right:
This board works with crossfire, does anything change when the 3870x2 is released? Could I crossfire 2 of those?
Does it SLI?
Will this board support the 45nm Penryn? And will it be missing any features?(kinda like phenoms working on a am2 motherboard but the HT is clocked down to 2 instead of 3GHz. Anything like that when using Penryn?)
Thanks in advance for any help.
yes, PCIE 2.0 16 x 2 lanes.
yes.
Does it SLI?
x38 is the latest Intel chipset. Nvidia chipset work with SLI.
yes.
The X38 has ALL the latest features available. I'm using it waiting for Intel's next round of 45nm processors.
Thanks badge, I'll probably go with this motherboard, and a Q6600 as soon as some HD3870's are in stock again. I think I'll buy those cards now and then when the 300$ penryn comes around Ill sell the Q6600 and get that, Same thing for the 3870's with 3870x2's.
Unless im being foolish, I think this is what im going to do.
...Please let me know if im being foolish!
Do you like the Maximus Formula boards? I herd they have been getting alot of flak. Just let me know your opinion...I was looking at either:
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131227
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131221
I cant figure out the difference between the last 2 though...
Also, do you think Ill have any problems dropping a Q6600 in that motherboard? The Q6600 FSB is supposed to be 1066 but the mobo is listed as 1600/1333. Is this just an easy OC for the Q6600 or something? What about my memory? I have the Crucial Balistix Tracer 1066.
