So I have had this CPU for a few months and have noticed this problem.
I have a entry a320 AM4 motherboard with this Ryzen and a CM Master Air g100l.
Now the R5 i have is 95 W TDP and this cooler supports up to 150 W TDP somewhere i saw ? Which is bs ?
In the summer it ran at 55-60c idle which is REALLY not good in my eyes and curiously maxed out at 75c on gaming BUT dropped to around 2GHz clock from the base 3.6 Ghz and Voltage dropped too.
It is currently still the same.
My case is REALLY BAD. Has only 1 place for a outtake fan and honestly has terrible air flow from what i think.
So my upgrade next week would be a 1660 Ti or a 2060 but I need to sort this problem out too.
What is better to do. Buy a new case or buy a new cooler ? Which is more likely to be the problem ?
If i have to replace both then i have to settle with a 1660 Ti but i definitely want the 2060 😀
Thanks for the help in advance!
