[SOLVED] RAID0 problems
mergh
6
System: ASUS ROG Strix Z690-I, i9-12900K, 2x Samsung 980 PRO M.2. Windows 11.
The MB should support M.2 gen 4 PCIe.
However, when setting up storage system in RAID 0 (via RST), I do not get more than ~7000/7000 read/write. This is the same as AHCI configuration with the two 980 PRO individually.
Windows drivers should be installed correctly, I guess.
The guide to setup the RAID is directly from the MB manual which link to this: https://dlcdnets.asus.com/pub/ASUS/mb/13MANUAL/RAID_Configuration_Guide_V2-EN.pdf
Any ideas?
No.
Done exactly right, a RAID 0 may, I repeat may, show great benchmark numbers.
In actual user facing benefit? Nada.
Here's a couple of older tests with RAID 0 and solid state drives.
http://www.tomshardware.com/reviews/samsung-950-pro-256gb-raid-report,4449.html
http://www.tomshardware.com/reviews/ssd-raid-benchmark,3485.html
tl-dr....No actual benefit at all.
What you DO get is increased complexity and fail potential.
Well okay, thanks. I will listen to you and delete the Raid volume instant :)
Reactions: USAFRet
