Hello all,
I have always wanted a powerful Micro ITX case and I recently made the jump of putting my high end components into the little Raijintek Ophion evo (With one small case modification to make it work)
To the point with details and Specs
8700K stock (Due to temps)
Zotac 1080ti Amp extreme
16GB DDR4 3200mhz
M.2 250gb
Asus Z390 Phantom gaming ITX
Pallas 120mm top down air cooler
2x Corsair ML120mm High pressure exhausts (Top)
1off Corsair ML120mm High pressure intake (Bottom)
Case dimensions - 174×375×290 mm
CPU TEMPS IDLE - 39-45c
GPU TEMPS IDLE - 45 - 54c
CPU TEMPS on load - 68-75c
GPU TEMPS on load - 65 - 79c (To get this temp I had to pack out on rubber grommets on the side panel to get more clearance otherwise if i didnt and left it at standard clearance due to the size of card I was hitting 85c to 89c) I have not done this mod to the CPU side panel yet
Fans are at about 60-70% which the noise level is bearable
Would you say these temps are ok for being in a micro ITX case and of course being air cooled? What could I do to reduce the heat within ?
I did think about getting a 240 watercooler - do you think this would reduce the excess heat from the case and the temps of the GPU might lower ? I did notice some performance issues which I had to get more clearance on the glass side panels. See picture below.
Modifications - Cut rear side panel to fit the card in, adding more rubber inserts to side glass to get clearance.
Thanks all
16GB DDR4 3200mhz
M.2 250gb
Thanks all
