NerdyComputerGuy
Hi,
So this is the current ram that I have,
KHX1600C9D3/4GX
I have 2 of these making 8GB ram in total.
I would like to upgrade to get 16gb of ram
I have found these two on Ebay, please could you tell me if they would be compatible with my system?
https://www.ebay.co.uk/itm/2-x-4GB-...069271?hash=item56ce9528d7:g:sLwAAOSwc~ddxS8p
https://www.ebay.co.uk/itm/Kingston...333867?hash=item262a4b47ab:g:Rg8AAOSwEFhdsv5d
I will choose one of these but want to know if it will be compatible.
I have an asrock z97 pro 3 motherboard.
thanks!
There are no guarantees whenever you don't use a certified kit. And even then sometimes if you get unlucky.
But from the specs, it looks like the kit you are about to get consists of the very same modules you use now (it is called differently merely because it is sold as a kit). So, you have a very high chance of everything working just fine.
