[SOLVED] Razer Blade Stealth 13 has a strange disk partition
zainvojr
56
Hello everyone!
I have a Razer Blade Stealth 13. While checking its Disk Management, I noticed a strange, no name disk partition that holds 15GB of the main disk.
Image: https://ibb.co/Qpv4hx0
My Questions are:
- Is the partition safe to delete so I could get that 15GB?
- If the answer for the above question is not, why is it not?
Thank you for your attention!
It's probably your factory restore partition. Its up to you if you want to delete it. Keep in mind there is no going back...
Also you will need 3rd party software to add that space to C: ; windows can't do it since its left of C: (windows can only do it if its on the immediate right of C:)
It will take time (90 minutes?) for software to complete.
But rule#1 applies - MAKE A BACKUP ! Of your whole drive, not just C:
