Alright, here is my situation. I'm trying to debug my PC, with which I am currently struggling with. Here are the important specs:
*AMD Athlon 64 X 2 3800+
*2 x 1 GB OCZ Platinum PC2-6400 Memory (dual channel, REV 2)
*ECS K8M890M-M motherboard
*MSI 7600GT Graphics Card
*Generic Raidmax 420 watt PS
Under normal, "surfing the net" work loads, the system is completely stable. However, after about 10 minutes or so of heavy gameplay the system completely restarts. Interestingly enough, there are no signs that would allude to a problem. For example, my last test, Call of Duty 5 was running perfectly smooth with no artifacts or anything prior to restarting.
My first guess was to try memory. In my bios, I originally had everything set to auto. So, i changed the timings to 4-4-4-15 @ 1.9V, as recommended by the OCZ website. After that, I ran MemTest86+, and it ran for an hour and a half completely stable, with no errors. Next, I updated the BIOS to the newest version.
My first instinct after memory was overheating, but I don't believe thats the case. It idles at 40 deg celcius. It isn't overclocked at all. I have 2 case fans (rear and side) plus a drive bay fan running. Also, I clean my case regular of dust.
Anyway, I next changed the setting so that windows doesn't restart immediately after BSOD. This didn't make a difference until after I changed my memory settings (first time it actually gave me a BSOD). Here is the error message:
IRQL_NOT_LESS_OR_EQUAL
STOP:0X0000000A (0x00000147,0X0000001C,0X00000000,0X805444DE)
I don't know how to decode STOP/BSOD messages
I'm wondering if it still isn't my memory. I might try raising the voltage again, to see if that will help. COD5 seemed to last a minute or two longer when I changed it last.
Anyway, any help or suggestions would be great. I've been working on this for hours and I'm not quite sure what to try next. I'm hoping the BSOD error message will lead me in the right direction. Thanks for your help!
