Question RGB exhaust fans not working
Aug 10, 2019
4
I recently built my own system using the new CORSAIR 220t rgb airflow or something like that and it was advertised to come with the new lighting node pro. After I installed a h150i in the front with 3 sp120s and 3 more sp120s as exhausts, I booted up my system and only the front fans actually had light. The exhaust fans were working but with no lighting at all! Can anyone tell me how to fix this? When I press my power button, the first exhaust fans gets a flicker of light for less than a second before going dark.
Yes and No, when in lighting style they appear but aren’t actually lit and depending on if you switch from sp pro edition to sp edition, only 3 fans fans will light up but every single one does it just depends on the mode and fan orientation. This makes sense because the pro edition has 8 LEDS while the regular only has 4.
