Hi,
I want to buy 2 120 case fans that are RGB which can be controlled via software. I have a Gigabyte B450M DS3H mobo and I want the fans to have varying speeds as well and not cost too much, ideally around £20/25$ or lower per fan. Any suggestions?
Edit: Will I be able to use the Cooler Master - MasterFan Pro 120 Air Balance RGB 42.7 CFM 120 mm Fan or Cooler Master - MasterFan Pro 120 Air Flow RGB 48.8 CFM 120mm Fan?
https://bit.ly/2XIg7Fb
Cheers
Cheers
