hey friends! I got an RTX 2060 at the beginning of this year and ever since I've had a few questions regarding temperatures, is 32/35c normal for idles and 50 to 60c normal temps during 40 to 55% load in gaming sessions? when under 70% load up to 100% it reaches 81c which that I'm not too concerned about, all that worries me is the other temps listed, are they normal? case airflow is decently good and right now where i live it's 20c but it can reach the high 30s in summer, will it be fine? thanks
SOLVED, EDIT: Turns out my high temperatures ingame were due to me setting my power management mode to Adaptive/Maximum Performance. If you're having the same issues as me simply set it to Optimal Power, that option will make sure the game/application you're using only uses the NEEDED amount of clock speeds and memory clocks to maintain a stable temperature and stable gpu utilization. if you monitor your GPU usage, you'll see that it's being used more than usual on optimal p. but it's normal, if you do something like disable VSync and compare both Adaptive/max perf to optimal power, you'll see you're still getting the same framerates, it just tones down the clock speeds and memory clocks when not all is needed. hope I helped someone out there.
